Vaico. Общая
Vaico. Общая
Оф.сайт http://www.vaico.de/
Интернет-магазин http://www.autoteile.de/en/product/list ... -0082.html
Бренд Vaico (а так же VEMO) принадлежит компании VIEROL AG (Сингапур)
Каталог VAICO https://yadi.sk/i/PYdbqFlejwJwu
PDS не нашел
MDSD гуглятся на сайт http://www.autodily-sklad.cz/img/a/162/ ... SDS_EN.PDF
MSDS на Vaico 0w-40
Vaico 0w-40.pdf
(197.94 КБ) 496 скачиваний
Коды (артикулы) для заказа Vaico
V60-0007 = G 052 162 A1 = Vaico ATF III G052162A1 1 L
V60-0010 = 60-0010 = Vaico SAE 20W-50 A2/B2E2 1 L
V60-0011 = SAE20W50/5 = Vaico SAE 20W-50 A2/B2/E2 5 L
V60-0012 = SAE10W40/1 = Vaico SAE 10W-40 SL/CF 1 L
V60-0013 = SAE10W40/5 = Vaico SAE 10W-40 SL/CF 5 L
V60-0014 = SAE 15W-40 = Vaico SAE 15W-40 A3/B3/E2 1 L
V60-0015 = SAE 15W-40 = Vaico SAE 15W-40 SG/EC 5 L
V60-0016 = 000 989 92 03 = Vaico ATF II D 1 L
V60-0017 = 000 989 91 03 = Vaico ATF Merce Special 1 L
V60-0018 = G 002 000 = Vaico ATF BMW Vag Opel 1 L
V60-0019 = G 012 A8 FA1 = Vaico Antifris G12 plus 1 L
V60-0020 = G 011 A8 CA1 = Vaico Antifris G11 1.5L
V60-0021 = G 011 A8 CA1 = Vaico Antifris MB 60 L
V60-0022 = SAE 15W-40 = Vaico SAE 15W-40 SG/EC 205 L
V60-0024 = SAE 20W-50 = Vaico SAE 20W-50 CG/EC MA 205 L
V60-0025 = SAE 5W-40/1 = Vaico SAE 5W-40 SL/CF 1 L
V60-0026 = SAE 5w-40/5 = Vaico SAE 5W-40 SL/CF 5 L
V60-0027 = SAE 10W-40 = Vaico SAE 10W-40 SL/CF 205 L
V60-0028 = SAE 5W-40 = Vaico SAE 5W-40 SJ/CF 205 L
V60-0029 = SAE 10W-50 = Vaico SAE 10W-50 SH/CD 205 L
V60-0030 = 000 989 9203 = Vaico ATF III 60 L
V60-0032 = 000 989 9203 = Vaico ATF II D 205 L
V60-0033 = 19 899 203 = Vaico ATF II D 60 L
V60-0034 = G 012 A8F A1 = Vaico Antifris G12 plus 60 L
V60-0035 = V60-0035 = Vaico SAE 10W-40 SL/CF 60 L
V60-0036 = V60-0036 = Vaico Windsreen cleaner 2 25ml
V60-0037 = V60-0037 = Vaico Windscreen VA 1:200 5 L
V60-0040 = V60-0040 = Vaico SAE 75W-90 1 L
V60-0041 = V60-0041 = Vaico SAE 75W-90 5 L
V60-0042 = V60-0042 = Vaico SAE 75W-90 GL4/5 60 L
V60-0044 = SAE 80w-90/1 = Vaico SAE 80W-90 GL4 1 L
V60-0045 = V60-0045 = Vaico SAE 80W-90 GL4 5 L
V60-0046 = V60-0046 = Vaico SAE 80W-90 GL4 60 L
V60-0047 = V60-0047 = Vaico SAE 80W-90 GL 4 208 L
V60-0049 = SAE15W40/60 = Vaico SAE 15W-40 SG/EC 60L
V60-0050 = G 052 162 A2 = Vaico ATF III-VW G052162A 1 L
V60-0051 = 60-0051 = Vaico SAE 0W-30 Longlife 1 L
V60-0052 = 60-0052 = Vaico SAE 0W-30 A5,B5 1 L
V60-0053 = 60-0053 = Vaico SAE 5W-30 longlife 1 L
V60-0054 = 60-0054 = Vaico SAE 5W-30 longlife 5 L
V60-0055 = SAE 0W-40/1 = Vaico SAE 0W-40 SL/CF 1 L
V60-0056 = SAE 0W-40/5 = Vaico SAE 0W-40 SL/CF 5 l
V60-0057 = 60-0057 = Vaico SAE 0W-40 205L
V60-0058 = 60-0058 = Vaico Dextron II D 5 L
V60-0059 = V60-0059 = Vaico SAE 5W-30 longlife 60 L
V60-0060 = V60-0060 = Vaico SAE 5W-30 longlife 60 L
V60-0061 = 60-0061 = Vaico SAE 5W-50 SL/CF 1 L
V60-0062 = V60-0062 = Vaico SAE 5W-50 5 L
V60-0063 = 60-0063 = Vaico SAE 10W-50-4T SL/CF 1 L
V60-0064 = 60-0064 = Vaico SAE 10W-50-4T SL/CF 5 L
V60-0070 = 60-0070 = Vaico Antifris G12 plus 5 L
V60-0071 = SAE 5W-40 PD/1 = Vaico SAE 5W-40 Pumpe Dus 1 L
V60-0072 = SAE 5W-40 PD/5 = Vaico SAE 5W-40 Pumpe Dus 5 L
V60-0074 = DOT 4 0,5L = Vaico DOT 4_0.5L 0.5L
V60-0075 = DOT 4 1L = Vaico DOT 4_1L 1 L
V60-0077 = V60-0077 = Vaico VA-011 Standard 5 L
V60-0078 = ATF III = Vaico ATF III 1 L
V60-0082 = SAE 5W-30/1 = Vaico SAE 5W-30 LA MB,BMW 1 L
V60-0083 = SAE 5W-30/5 = Vaico SAE 5W-30 LA MB,BMW 5 L
V60-0084 = SAE 5w-30/1 MB = Vaico SAE 5W-30 LA MB,BMW 1 L
V60-0085 = SAE 5W-40/5 = Vaico SAE 5W-30 longlife 5 L
V60-0092 = ATF LL VA-6HP = Vaico ATF loglife VA-6HP 20 L
V60-0100 = V60-0100 = Vaico SAE 5W-30 LL 60 L
V60-0101 = V60-0101 = Vaico ATF Spezial_1L 1 L
V60-0102 = 60-0102 = Vaico SAE 15W-40 Lkv
V60-0105 = SAE 5W-30 = Vaico SAE 5W-30 PSA 1 L
V60-0106 = V60-0106 = Vaico SAE 5W-30 PSA 5 L
V60-0107 = V60-0107 = Vaico SAE 5W-30 Spezial R 1 L
V60-0108 = SAE 5W-30/5 = Vaico SAE 5W-30 Special R 5 L
V60-0109 = SAE 5w-30 F/1 = Vaico SAE 5W-30 Special F 1 L
V60-0110 = SAE 5w-30 F = Vaico SAE 5W-30 Special F 5 L
V60-0111 = DOT 4 5L = Vaico DOT 4 5L 5 L
V60-0112 = VA-LHM/1 = Vaico VA-LHM 1 L
V60-0113 = VA-012++_1.5 = Vaico VA-012++ 1.5 L
V60-0114 = 60-0114 = Vaico VA-012++ 12 L
V60-0115 = V60-0115 = Vaico VA-RE Antifriz 1.5 L
V60-0116 = V60-0116 = Vaico VA-PSA Antifriz 1.5 L
V60-0117 = V60-0117 = Vaico ATF CVT 1 L 1 L
V60-0119 = V60-0119 = Vaico VA-RE Antifriz 5 L
V60-0121 = V60-0121 = Vaico VA-PSA Antifriz 5 L
V60-0123 = 60-0123 = Vaico Windscreen Cleaner 1 L
V60-0124 = V60-0124 = Vaico Windscreen Cleaner 5 L
V60-0125 = G 052 990 A2 = Vaico ATF 3353 1L 1 L
V60-0127 = V60-0127 = Vaico VA-PSF 236.3 1 L
V60-0128 = SAE 5W-40 PD/6 = Vaico SAE 5W-40 Pumpe Dus 60 L
V60-0139 = = Vaico Windscreen Defrost 0.5L
V60-0140 = = Vaico Windscreen Defrost 2.5 l
V60-0164 = = Vaico Antifriz G13 1.5L
V60-0165 = = Vaico Antifriz G13 5L 5 L
